Need info on 70 GTO
GTOGeorge
I am trying to find out what the 3 screws are that go straight up through the IP one above the speedometer ,the clock ,and the gauges. I can`t find these anywhere.
Thanks
21,089
172
63
I have a 71 and I believe the dash is identical to the 70. Original owner.
No screws in the area you mentioned.
Can you post a picture?
GTOGeorge
The screw head goes up through the hole and through the gauges and into the upper dash where there are nylon inserts and this keeps it from rattling and secures everything in place. My screws were missing and without taking the dash back out Iam not sure what the size and length of the screws.
Thanks for the reply.
21,089
172
63
I was looking at the dashboard not the bezel. The screw is a Phillips head, black, 1/2" long from the base of the head to the point, 1/8" at it's widest point immediately under the head.
