Need Some Tip P0442
Lavell314
Hello recently drove my car only have 110k I have that code pop up and what wondering how can I fix it myself I change out the purge valve acdelco and replace my gas cap acdelco also but still remain, any tips would be ok to fix these code on my Gxp 08. Thanks
Did you clear the code after each repair attempt?
Only other thing to try is look up how to do a DIY smoke test.
mrbreezeet1
Member
What did you come up with?
Lavell314
I change out the canister vent solenoid behind the rear left tire behind gas tank, found a replacement on Amazon from GM it's been doing me good n plus the old part was in bad shape so I'm good now runs great
