No ABS Speed sensor in wheel bearing....?
Nate.plotnikoff
Hey guy as the title says this car does not appear to have an ABS sensor/ speed sensor in either passenger or driver side wheel bearings. The bracketry from The Hub to hold the quick connect is present but there is no wiring coming down the a arm to the hub assembly there's no ABS codes on the car itself but I have noticed that I can lock the brakes up when I apply pressure heavily 15900889135942891891379880837505.jpg
22,654
330
83
To start with what year is the car and do you see the ABS module under the hood?
Nate.plotnikoff
The car is a 2006, I believe its base model. 3.8 w/o supercharger. And no theres no abs module under the hood. I though that this car would have ABS respectively 2006 isn't terribly old of a car...
Nate.plotnikoff
It's not my car. It's my grandmother in laws car. Her grand son took the car out one day and blew the transmission in it. So I got it over at my place found an engine transmission from a written off car same year same trim package with only 100,000 km and managed to get the engine and trans for 300 bucks so I'm swapping them over for her. And trying to get any other issues addressed at the same time. She doesn't have the money to buy a new car, and National transmission quoted $4,300 CAD to have it rebuilt. 18 hour @ $120 and about 2,200 for parts.
