No Guage Sweep, Crank but no start
Speedy220
I have an 04' Grand Prix that will crank but not start. Last time it was running the interior light started to flicker and then it stalled. I have not been able to restart since. When the key is set to the on position there is no Guage sweep. How do I track this issue down in order to fix. The computer does not throw any codes.
Test fuel pressure, spark, crank sensor.
cammerjeff
Active member
Belleville MI
Also what is the battery Voltage? Modern cars do all kind of strange things if you do not have at least 12.0 volts on the battery. 11.8 will start causing odd things to happen.
Start on the simple things, like cleaning the battery cable connections, & checking the Battery Voltage.
Speedy220
Battery was replaced along with the alternator last year. I will have the battery checked. Should be good though,.
