Power Window Motor & Regulator - 1991 Sunbird Convertible
Zip
Member
35
8
8
I'm having trouble locating the correct replacement window regulator / motor assembly for my 1991 Sunbird CONVERTIBLE. See the attached picture - I need the unit with the additional arm - all the replacement ones on line don't have that extra arm - it won't work without it! The original is on top in the picture......
Zip
Member
35
8
8
I detached the motor....it is frozen up....will try to source just that. Regulator arms look fine. Almost killed myself when the spring detached itself.
92 Sunbird LE
62
48
Salinas, Puerto Rico
No replies yet, looked on JBody.org and V6Z24 sites also , nothing there in old posts either.
Did GM build these convertibles or farm them out for the conversions?
Hopefully you can drill out the rivets and replace the motor, the old posts say something about the new bolts are too large and you have to enlarge the holes for the bolts, also to use Loctite or JBWeld to assemble the bolts and nuts back on the regulator.
Doug in P.R.:cool:
Zip
Member
35
8
8
Now where can I find a Tech I scan tool to quick-learn Idle Learn Procedure? Sigh.
62
Doug in P.R.:cool:
Fun fact:
GM never built a convertible.
They always outsourced them.
