Question ?
20,318
134
63
what intake are you using, looks very tall?
Tfrias
Member
91
A stock 1966 389 cid w/2 barrel YA block compression was rated @ 8.6 With valves, guides, rings upgrades and .010 thinner head gasket it is @ 9.0 The cam is a Comp Xtream energy XE262H. Nothing special but a big improvement over stock.
20,318
134
63
The 4160 is a 600CFM or more? Guess your going for a RPM limit of 5,500 ?
Tfrias
Member
91
You are correct 600 CFM. It already has hit 5500. Not that it will all time but nice to know the is someting extra there if needed.
