re: overhead light above the rear view mirror
reble
Member
72
Kennewick, Wa
I pulled the light/switch assembly out so I could rig a manual switch (both of the original switches are busted). How do I get the light assembly back in? and how do I get the outer cover over the lights back on? I can attach a picture if needed.
Steve
21,638
215
63
I assume you mean the map lamp.
There is a 1AAuto video on removing a map light on an Equinox, check out if it is the same.
reble
Member
72
Kennewick, Wa
I guess there called map lights. The 2 lights are dead center above the wind shield and the rear view mirror. The lights normally come on when one or more of the doors are opened. Or push the manual over ride buttons. The buttons are busted. I am trying to rig a switch to get one of the lights to turn on in manual over ride mode. BTW this is on a 2008 Torrent. What is an Equinox?
21,638
215
63
The Chevrolet version of the Torrent
reble
Member
72
Kennewick, Wa
I looked at the video for the map light in the Chevy Equinox. It is not the same as the Torrent. I still don't know how to put the map light assembly back in place.
21,638
215
63
What I'm unclear on is you knew how to remove it, what is different in reinstalling it?
