Rear ride height differences.
Boprop
I have an 02 grand prix I recently replaced the rear struts. Now I have noticed the ride height is off. The driver side sits between 1" and 2" higher than the passenger side. What could be causing this issue?
18,753
27
48
you confirmed you were sold the correct parts?
did you or a shop do the work?
was it a complete assembly with springs or you swapped the springs?
did you loosen the trailing arm and lateral rod bolts with the full weight of the vehicle on the suspension and then retorque them?
