Recommendations in CT for head rebuild?
mgoneill70
My father passed down his 1971 Formula 455 H/O to my brother in the late 70s after having Ram Air IV heads installed and subsequently blowing the motor. Fast forward till now, still have the Ram Air IV heads in basement and one needs a machine shop to inspect and determine if it can be repaired. Any recommendations for experienced machine shops in CT or tri-state? Much appreciated.
18,654
17
38
mgoneill70
Which might explain the disaster that took place shortly after the RA IV heads were installed. Then again, because of that, the car sat in our garage until the 80s with less than 8k miles before my brother put another 455 in it. He still has the car and would like to do a total restoration so figured I’d get these heads checked out and go from there. Thanks.
18,654
17
38
If you can provide a casting number it might help to confirm they are actually RA IV heads. The 71 455 HO head was somewhat similar due to both heads having round exhaust ports compared to the standard D port of other Pontiac heads.
mgoneill70
My father was a real car guy back in the late 50s thru the 70s so I'm certain they're RA IV heads. I still have the original Shelby 10 spoke wheels from his 66 Shelby GT350 along with the rear "wing" off his 1969 Hurst Olds (455 H/O, white with gold stripes), he ended up taking the wing off and painting the car British racing green because the cops were pulling him over all the time. He also had a 67 327 Corvette for a short period that he hated the handling of. Anyway, the 71 Formula was his last muscle car before he started driving Chevy Blazer's and Suburban's in the 70s. He had a Chicago engine shop (I believe owned by the Granatelli Brothers) install the RA IV heads on the Firebird and blew the motor driving back from Chicago to CT. Like I said in an earlier post, that's the only reason the car stayed in the family as it remained parked in the garage for about 10 years.
18,654
17
38
Have you considered the value of those heads to someone restoring a 1969 RA IV and using the money from the sale for a set of Edelbrock aluminum heads intended for a 455?
