Remote start
John G
The remote start on my two key fob works once in awhile. I hit the start button, and the car starts within seconds. The next dozen times- nothing. Everything else on the key fob works fine: lock, unlock, trunk, horn. I am wondering if the receiver has started to go bad and only works intermittently. Any ideas out there? Thanks.
Have you tried replacing the FOB battery?
John G
The batteries in the FOB are brand new. I checked voltage before I replaced them.
If the other functions work it could be the board in the key FOBs for the remote function. Have both FOBs been used equally over the years?
John G
I would assume so. By process of elimination, both FOBs start the car. A few days later, neither FOB starts the car. And it hasn't worked since then. I suspect that the electronic module that receivies the signal is starting to go bad. The previous owner has stated that she has not had a problem with remote starting. I suspect it is the module. Now the trick is to find out which module is the bad one and how to get a replacement.
