Rims and Tires for a 1971 Lemans Sport
TGasparolo
All,
I need a wider tire for my Lemans Sport. I have been told I can put P255/60R15's on it and even 275/60R15's. Has anyone had any experience with this? I don't want to modify my fender wells for tires.
I'm not a gear head so please keep to the KISS method.
Thank you!
Tom G
20,248
130
63
I have 235/60x15 in the front and 245/60x15 in the rear. You make no mention of what you have now but if you have 235/60x15 the 255 is almost 1" wider and the 275 is almost 2" wider.
TGasparolo
Thank you, I'm in Dallas right now and will be home on Thursday and will check what I currently have.
TGasparolo
Melsg5,
I have P235/60's all around and my rims are 15 x 7 with a 6mm offset. The difference between 235's and 275's is only about 1.6" wider correct?
Thank you for all your input!
20,248
130
63
just remember to check your speedometer accuracy with a phone app.
Slartibartfast
Of no use to the OP but of possible use for future generations, the 255/60 is 3.3% larger in diameter and will make the speedo read a little over 2 mph slower. 255/55-15 is almost exact same diameter as the 235/60-15. Now, I have no idea if that size is available.
