Security bypass
03pontga
So my 03 grand am decided to have the passlock system fail 30 miles from my house at a friend's. Is there a key dance I can do to bypass it? Also when I replace the ignition switch is it a 30 minute program time frame in 3 ten minute intervals or one 10 minute? But I need to know if I can do that to get the car home
19,710
81
48
  1. Turn ON the ignition, with the engine OFF.
  2. Attempt to start the engine, then release the key to ON (vehicle will not start).
  3. Observe the SECURITY telltale, after approximately 10 minutes the telltale will turn OFF.
  4. Turn OFF the ignition, and wait 5 seconds .
  5. Repeat steps 1 through 4, 2 more times for a total of 3 cycles/30 minutes. The vehicle is now ready to relearn the Passlock Sensor Data Code and/or passwords on the next ignition switch transition from OFF to CRANK. IMPORTANT: The vehicle learns the Passlock Sensor Data Code and/or password on the next ignition switch transition from OFF to CRANK. You must turn the ignition OFF before attempting to start the vehicle.
  6. Start the engine. The vehicle has now learned the Passlock Sensor Data Code and/or password.
  7. With a scan tool, clear any DTCs if needed. History DTCs will self clear after 100 ignition cycles.
