Security System Going Off
Ndennis23
MD
I have a 1999 pontiac grand am and my battery kept dying so I have been jump starting it past couple weeks. This time when I jumped it today the alarm is constantly blaring afterwards. I tried to start the car to turn it off. The car starts, but the alarm keeps going. It doesn't do a theft lock or anything. it just keeps blaring. I need help resetting or finding the fuse for it and removing it. Please help
Ndennis23
MD
It is the horn and the lights. It doesn't lock up, but the lights blink, horn blares, and the odometer keeps blinking. I thought there was a valet switch under the dash so i pressed it, but nothing happens. So tomorrow morning im going to try to follow the horn wire to see if I can find the alarm fuses.
18,654
17
38
did you try inserting the key into the door and manually unlocking the car?
18,654
17
38
you mentioned a switch under the dash, did you trace where that goes? It is not a factory switch.
