Stabilitrak and check engine light
robb4640
Brantford
I have non stop issues with this. Have replaced the egr valve, accelerater pedal/sensor and throttle position sensor as these are what the codes have been and still having same issues. Anyone have any other ideas??
Hutchy
What's the issue? I've had a bad pickup on wheel bearing trigger a stabilitrack message and code. Turned out, we just replaced the wire.
robb4640
Brantford
Just finally got a chance to check codes. Now p0404 code is coming up. Egr valve has already been replaced and the medal tube also been replaced.
