Starter removal
joeharris5902`
I have removed the starter from the transmission on a 1995 Firebird with a 3.4 engine and have it completely off of engine. The problem is how to get it out, it is like the exhaust is in the way. Does anybody have any solutions or ideas without having to remove the exhaust?:confused:
This is a post where he states he loosened/removed it but states he wouldnt do that again.
1. Disconnect the Battery ground cable from the battery
2. Raise the vehicle or use ramps....higher is better...but be safe.
3. Starter is on the Driver side. Taking off the tire is an option if on jackstands.
4. Remove the Starter shield. ( I did remove or loosen the exhaust, it was a waste of time..and I broke two of the bolts off in the manifold. Would not do that again!!!!
5. Disconnect both the electrical connectors from the starter..
6. Remove the starter bolts... 2 of them. Take the one off that held the shield first...easy to get too.
7. Now the 2nd bolt...a thin walled 15mm short socket. If you don't have a thin one, this is what is had to do...
8.. Remove the inspection cover bolts for the starter ring on the Driver side. Also remove the 2 side mount plate bolt ( 13mm socket). On the passenger side...you only need to loosen them about 3 turns...3 bolts and 2 side mount plates
9.. This will allow the inspection cover to move away (using a big screwdriver) enough to give clearance for the 15mm socket to go over the head of the bolt. (I used a 1/2 drive socket with a 8" extention)
10. Slowly remove the 2nd bolt...hold the starter...it will now almost fall out.
11. Basically reverse the process with the new starter. Check the manual for the torque specs for the other bolt. I guessed at it..could not find them in my manuals.
12. My car had no shims under the starter....I did not check the starter ring to pinion clearance... .5mm or .020"...
