Strong gas smell Grand Am GT 2003
Pepples
North Dakota
When I start my car, it takes multiple ignites,( holding the key to start) and revs before the engine actually gets going, then when it does start, a very rich gas exhaust is all around the car, very strong. I do know I've gotten a trouble code P0300. Helpful tips- I've had my pressure control valve ,PCV, recently replaced, and it does go to high RPM before it hits 5th gear on to interstate
G
G-915787
Have you replaced the fuel pressure regulator? Common issue, especially with the fuel smell. It can leak in the engine bay (how my first Bonnie caught fire)
