T400 transmission mount
69catguy
Member
The mount that came with the car has offset holes they are not in a straight line. The 2 bolt holes on the transmission are in a straight line. Doesn’t seem correct. When I bolt it to the transmission the mount sits crooked. Looks like it won’t sit in the crossmember square.
You have the wrong mount.
Are you sure you have a TH400 and not a TH350?
avell007
Member
Wilmington, Ma
Thats not the right tranny mount ames lists , my 70 has offset holes with one stud not two threaded holes, the mount sits angled. The first time I saw it I thought a bolt fell out but no its angled. Not sure if its a Catalina thing but Rock auto sells the angle one that fits.
nwclassics
im parting out a 69 catalina with a 400 auto it well have the corect mount call george 406-5432591
69catguy
Member
Thanks. I found a standard mount with 2 straight bolt holes and 1 center mount bolt. It seemed to bolt up ok. I hope it will be ok.
69catguy
Member
It just seemed like the the way it bolted up on angle was not correct. Maybe I should take out the one I installed and put the angled one back in.
