Tail lights
dj92alx
I have a 1996 Pontiac Bonneville SSEI my tail lights and license plate lights are not coming on at night but the break lights work. I just changed the bulbs today and the bulbs will light up for the brake light but just for the running tail light it's not lit. I did check the parking lamp fuse, and the fuse is good. Can someone please assist
20,243
130
63
can you check the bulb socket for power with a voltmeter or test light?
you could have a bad switch, a broken wire, or a bad ground.
dj92alx
I don't have a voltmeter but the same socket is used for the brake lights in the brake lights still work, plus the license plate bulb is out after it being replaced and that runs off the tail light circuit also.
20,243
130
63
doesnt the socket have two contacts?
20,243
130
63
back to a bad switch or ground but it can be confirmed by working with a voltmeter and ohmmeter to see if power is going in to the correct socket contact and that the ground is good
92 Sunbird LE
44
48
Salinas, Puerto Rico
Could also be corroded wires, you are going to have to follow the harness from the rear to the front. If there are connectors in the harness, check them also for corrosion.
On most GM cars of this era, the wires run inside the car on the driver's side.
Usually just speaker wires run on the passenger side.
Black ( ground) , brown , green and yellow are usually the light wires. They are usually together.
Doug in P.R. šŸ˜Ž
