• If you're looking for help and want to draw people in who can assist you, use a descriptive subject title when posting your message. In other words, "1995 Trans Am" isn't going to indicate to anybody that you need help. However, "Need help with my 1995 Trans Am" will. Be as descriptive as you can. Please use common sense...
Tire size?
19,251
57
48
looking at the American Racing wheels web site they show wheels as large as 17x7 for a 64 Catalina. Measure your width clearance in inches and multiply by 25.4 to get a tire cross section such as 245. The original tire I believe has a 28" diameter. (28" - 17")/2=5.5" sidewall height. 5.5"*25.4=139.7mm sidewall height. (139,7/245)*100=57 roughly a 60 series tire. So the tire size if you can fit a 245 is 245/60x17. I know, too much math.
Fred Engelhard
St louis
Thanks there’s nothing wrong with to much math. Unless I am adding it up it’s never right. When you are trying to put the biggest and fattest tire possible. With backspace it makes my math wrong before I start
