88Firebird
- Nov 1, 2011
I have a 1986 Trans Am with automatic transmission. Recently the transmission does not want to shift gears until the engine is at a higher rpm than normal. I was told the modulator valve may be the problem but I was also told this vehicle does not have this valve. Is there a modulator valve on the 86 trans am? If so,where is it located? Also,any other advice would be appreciated as to possible solutions. I have changed the transmission fluid and filter but that didn't seem to have any effect. Any help would be greatly appreciated. Thanks
