Transmission fluid flow?
RWB
04 Bonneville, Hello all, I want to add an external transmission cooler but not sure which line is the return from the cooler tank in the radiator.
Any info would be great!
G
G-619196
Thanks for responding, I don’t think I phrased my question clearly as to what info I’m looking for. What I need is what direction does the transmission fluid flow thru the cooler tank in the radiator? One line is fluid going in from the transmission and the other is the return back. I need to know which is the return line back to plumb in the cooler.
21,513
207
63
I gave you the location of the return line on the transmission. Just follow the line back to the radiator.
G
G-713233
Somehow I missed the link you provided so that’s why I asked about it again. Pays to be observant! I appreciate the info greatly!!
