Transmission leak question
TourNut
I have a '93 TransSport , 3.8 l , with 4 speed 4T60E transmission. I t has developed a major leak somewhere up on the side of it , ( not the pan - which has been redone recently ) It is peeing on the ground the most severe when you are giving the gas to the engine . What would do that and can something be replaced from the outside of the tranny , while it is still in the van ?
Thank you for replies .
TourNut
Cleaned it all up under there , started the engine : result was a major ATF flow out of the left axle tranny seal and a second lesser one coming out between the engine and transmission . To fix both would be a transmission drop and rebuild .
