Ventura 1976 350 5.7L - What is this ?
92 Sunbird LE
44
48
Salinas, Puerto Rico
Nutsert or Helicoil is the best way to fix it right but requires a special tool install.
Tap out and use a bigger bolt is easiest.
Weld up the hole with aluminum mig wire, drill and retap requires great aluminum welding skills.
Permatex makes a thread repair goop but there are mixed reviews if it works or not.
Pick your poison.............................;)
Doug in P.R.:cool:
92 Sunbird LE
44
48
Is there any kind of high pressure in the pan?
Like It's a through hole may be that I can simply use a longer bolt an put a nut at the other end?
Not much pressure in the pan area but like 300 lbs interally. but trans fluid is so thin it leaks real easy.
I allways Permatex the gasket on both sides and install and let it sit 24 hours before adding fliud for a tight seal.
The best stuff I ever used was windshield urethane, never, ever leaked but was a bear to clean off your hands and anything else it gets on.
Hopefully you get a rubber gasket with you filter, cork doesnt last long.
Doug in P.R.:cool:
Ventura76
Quebec, Canada
"Tap out and use a bigger bolt is easiest"
That's Funny Doug!
Don't you remember what did happen the last last time I tried to do that :)
This time I will drill before tapping out
Ventura76
Quebec, Canada
Second brroken bolt is now out. The hole is way more cleaner than the first one (no broken plug)
Now I need to take some time to choose what to do with the first hole. I am really scared by this one. It has got a conic shape and I believe I have to partly fill in it if I want to avoid a serious leak.
I will use some permatex plus the gasket but.....
Ventura76
Quebec, Canada
Finally I have decided to use a good tap.Today I Finished the two holes and clean everything. I bought 11 new bolts of the original size and two bigger and guess what.... the 11 don't fit. The originals have that strange thinner tip and I found out why today.
So NOW I have to find 11 bolts that fit.....
3 weeks to change a transmission filter.... I can't believe it
92 Sunbird LE
44
48
Turbo 350 pan bolt specs: 5/16" x 1" SAE Grade 5
Overall Length: .95"
Under Head Length: .75 "
Thread Pitch: 5/16"-18
Hope that helps Frederic..........................;)
Doug in P.R.:cool:
Ventura76
Quebec, Canada
Thanks Doug, I will keep that for my archives, very helpfull.
The new pan is now in place. I re-used the original bolts after a good cleaning. I also used permatex.
Now I will wait tomorrow to put the ATF. I am scared to see a big leak tomorrow.
Cross your fingers.
After that, I will need your help to find out how this engine can run with so much hoses and connectors not plugged :)
Thank you Doug
92 Sunbird LE
44
48
Cross your fingers.
Thank you Doug
You'll be fine................;)
Does the car still have the Emmision sticker attached like this?
http://repairguide.autozone.com/znetrgs/repair_guide_content/en_us/images/0900c152/80/0b/10/45/large/0900c152800b1045.gif
Doug in P.R.:cool:
Ventura76
Quebec, Canada
Yes the sticker is attached.... I feel stupid one more time :)
I put the ATF this morning and....................... the thing doesn't start.Come on.....
The battery is fully charged and everything seems at the right place. I don't know, may be I have to kick somewhere :)
Sounds like not enough power. The dashboard lights are OK and strong, the awful noise for the open door is OK too but when I turn the key, nothing (no noise, nothing) except that the light is getting low
20,318
135
63
do you have a voltmeter, should have 12.75 volts on fully charged battery. Check the battery cables for bad connection.
Ventura76
Quebec, Canada
13.12 Volts when I touch the connectors, I can have a little and single "Click", then the GEN light get low.
I will try to boost with my other car when mama will be back.
Hey; I am finaly not that stupid, on my sticker, there is no schema. But on the left, we can read BC 350 CU. IN. 40J2
May be:
BC for Buick :)
Ventura76
Quebec, Canada
Car did start after trying to remove and play with the battery cables (thanks melsg5)
No trace of major leak on the pan but I put a lot of ATF more than 6 liters and the deep stick still says low and I didn't engage any gear
