What does the starter look like for a 2001 pontiac sunfire with 2.2L ?
Dave Lawson
My brother has 2001 pontiac sunfire,he told me his car won't start ,maybe it's time to replace a new pontiac sunfire starter.
I want to give him a surprise and order a sunfire starter replacement for him.
So what does the starter look like for a 2001 pontiac sunfire with 2.2L engine?
Thank you.
19,165
48
48
you first have to figure out why it wont start.
does the engine turn over when you turn the key? if not check the battery with a voltage meter, need at least 12.5 volts.
Next check at the starter solenoid if you have voltage when the key is turned to start.
Try that and let us know the result before you try replacing a starter.
Herman Unger
I fully agree with melsg5.Well,before you buy a new starter replacement,you had better do more testing.Have you also checked the starter relay or maybe a loose ground? Two months ago,I thought I needed a new starter,so ordered in Hexautoparts.But then I got my pontiac running and no longer need it.Finally I returned it and got my refund with easy return policy.
