What size wheels can i fit on my 1968 Pontiac Bonneville
XBallX
Hello, I was wondering if anyone has any first-hand experience of wheel sizes for 1968 Pontiac Bonneville. I have done a lot of research and keep coming up with conflicting answers on the sizes, offsets, etc that I can put on the car. Especially the rear, due to the wheel wells limited room. If anyone has put bigger tires and wheels on and can help me out, I would be very grateful.
21,193
183
63
the stock tire/wheel measured a little less than 28" in diameter and the stock width was 217mm.
have you done any actual measurements on the car to determine how much clearance you have on both the inside and outside of the tire sidewall?
have you measured your wheels for offset and backspace?
the next size up from 217 is 225 so you could fit a 225/60x17 tire.
you may be able to go as large as 245/55x17 which would be a little less than a inch wider than the 225/60x17, but you need to know if you have a 1/2' clearance on both sides of the tire.
