wheel cover compatibility
FatherTime
upstate NY
I'm wanting to get some aftermarket wheel covers for my 09 base. It has the wheel covers that have the integrated plastic nuts that screw onto the actual lugnuts. Anyone know if there are any compatibility issues I may run into?
21,494
206
63
The plastic nuts are purely decorative so as long as the cover fits over the whole wheel I can't imagine an issue. There are also so many covers out there buying them locally so you can easily return them may be better.
FatherTime
upstate NY
I was thinking maybe the threaded lugnuts might be longer (?) than normal lugnuts preventing the new covers from seating properly. But other than the lugnuts, these are just regular old steel wheels right? If that's the case case, I could just get different lugnuts put on I suppose, if there was a problem.
