Where can I get replacement washers of this kind? Pictures included.
Satan
Hi, this washer is found holding the MAF and also on the window washer fluid reservoir on the driver's side of my 2000 Grand Am. The bolt it had was 10mm, but I doubt that's relevant.
Reason for replacement: the rubber is cracked and all of the components it holds are quite loose.
Thanks for reading.
Satan
220394457 , any GM dealer or look online
I saw that but I thought it wasn't it because the pictures I find are so different... well I went ahead and ordered 3. I probably don't need them, but I guess I'm a perfectionist. I tried to makeshift by using my own washers but it's harder than it seems.
BTW, it's 22039457. You put another 4 by accident.
