Wipers help
My wipers stopped working! The washers still squirt, but when I tried to switch on the wipers, they raised up ready to wipe, but then just moved up and down around an inch or so!
Is there some kind of limit switch that needs re-setting?
cammerjeff
Member
429
Belleville MI
As your washer works I am assuming the wiper motor is working as it drives the mechanical style washer pump, that and the fact that the wipers move up and down an inch or so.
I would inspect the linkage from the wiper motor to the wiper arms. I suspect that the nut that secures the linkage to the motor is loose, or the linkage itself is damaged at the conection point.
That is assuming that both wipers move the same amount and together.
Good luck, please let us know what you find.
