‘76 Catalina - Recommended Repair Manual(s) ?
76-catalina
Hey everyone! I am a new proud own of a 76 Catalina. All original with 54K miles. I have a few things that I want to fix now and I am sure there will be more as time goes on.
I am looking for recommendations on repair and/or assembly manuals that I should keep on hand. These manuals aren’t cheap and I would to make sure I get the "best" one...
Thanks in advanced for the help!
Thanks for the links! I bought them both. My first job is to replace the rear springs.
Other than for possible rusted attaching hardware that should be easy. Place the rear frame of the vehicle on jack stands. Remove the rear wheels disconnect the bottom shock attachments, remove the springs. Before you start check the condition of any rubber spring insulators so you have them if needed. Good luck.
