R
(:RockStar:)
Just recently, when I go to crank it, its like it has no gas going to the engine, but after doing 3 cranks on it, it finally turns over. Whats the deal on that? I have replaced the spark plugs and boots. has a good battery and alternator, starter motor and solenoid is good. 115,000 miles. 2.4L DOHC. Could it be a bad fuel pressure regulator, or any problems with the pump? Also, what is the device called that restricts fuel from returning to the tank from the lines after the car has been shut off?
