Static Sloth
- Jun 21, 2013
Hello,
My check engine light came on recently and I had someone use a device that shows the engine error code. It came back with the following reading:
"P1810 - ATF Pressure Manual Valve Position Switch Malfunction."
I was wondering if anyone could help with this? I am not knowledgeable with fixing cars myself but I know a few people that are, so I will relay any information I get to them to see if they can help. The car is an automatic.
And in case it is of any importance - I recently had the waterpump changed, as well as the coolant system fluid flushed out and replaced with new fluid. The timing chain also jumped a tooth I guess when the mechanic was replacing the waterpump which caused my engine to be rocking back and forth when driving, but I brought it back to him and he fixed it.
Thank you for any assistance.
