Hi,
I just bought this car and the washer fluid is not spraying and level warning is on even though it's full and I don't hear the motor. I inspected the reservoir an noticed the sensor plugged into resevoir where the wire plugs in is busted and can be pulled out.
I'm not sure if this is two issues or the root of the issue?
Thank you!
Thank you!
