I went to my local auto parts store Nd bought what I thought was the correct belt for my 03 grand am. I also replaced a bad idle pulley. When I finally got it on the belt was touching side of the tensioner. I knew if I started it up the belt would instantly shred.
I took it off and went to the store again and double checked the numbers and it was the same one again. I asked if they had a longer belt so they checked the 04 grand am and it was .5 longer, I think. Got home and put it on and all looked just fine. Only after a month the belt started to shred. So I got it replaced under warranty and now that belt is starting to shred as well.
What is happening? I doubt they will replace the belt again plus I dont want to keep doing this. The original belt was fine but squealed something terrible. I did compare the belts and the new belt seemed a little short to the original.
