04 Grand Am Trans Pan Bolt Size
AWickham
Unfortunately, I snapped 1 head off the bolt that hold the transmission pan in place. I have not been able to find out what size/pitch the bolt is that I need to replace.... Help, PLEASE?!?!
Dont you have the other bolts to use as a comparison when you go to buy a new one?
assuming you have removed the broken bolt, you just need to leave one bolt off the pan opposite the missing bolt to make a match, reassemble and fill, drive to store and get a new bolt.
BOLT,A/TRNS FLUID PAN) (M6 X 1.0 pitch X 19 mm - 9.8 Hardness) (ACDelco #24203911). Required: 12
For: J 4-SPD A/TRANS(MN4) (1995-2005) (1995 - 1996).
Doug in P.R.:cool:
