Trailerlight
- Apr 10, 2012
Greetings all, I have a '04 Montana and I am having an issue with the trailer lights. The Right side works fine, But the left side only seems to signal when the brake is applied. At the 4 pin connector I read 3.5v on the flash which obviously is not enough to illuminate the light (led setup) but when the brake is applied I read 11v and the signal functions. I can not find a repair manual in town so I can see the circuit on paper and I believe it's a grounding issue in the vehicle but I'm wondering if there is any other pieces in the circuit that it could be.
Any insight into this problem is appreciated. Rick.
