04 Pontiac
  • Thread starter Thread starter bethnoellewhite
B
bethnoellewhite
Sunfire problems? I have an 04 pontiac sunfire that has a myriad of problems. The biggest ones right now are 1) one headlight only turns on the daytime running light 2) the front defroster doesn't work 3) the cigarette lighter doesn't work.
My main concern is with the headlight. I replaced the bulb but that didn't seem to be the problem. Does anyone know what the problem may be and how to fix it/approximate cost?
You say that you have many problems. Only some may be connected. First thing that I would look at would be the fuses. Check that the fuses for the relevant circuits are OK and that you are getting power to the units.
If you don't have one, get a Haynes or Chilton manual and that will help.
