05 Grand AM GT
Pj 60
Hi, I am new to this site, so hopefully you folks can help. I have just purchased an '05 Grand AM GT Ram Air, with 175,000 Km on her. My problem is the dome lights don't work ( I have checked the fuses, and changed the lights), the power locks don't work properly (I can unlock them with the power door button, but I have to lock them manually, the power door lock button will not lock them.) The power trunk release button on the driver door dose not work. There are no trouble lights showing on the dash. Dose anybody have an idea what the problem might be? Thanks, Paul.:(
1. The dome light doesnt work when you open the door and the light switch wont turn them on also?
2. Does your remote lock the doors? If it does than it sounds like the door switch is bad.
3. Does the remote open the trunk? If it does than the trunk switch is bad or there is an open between the switch and the trunk.
http://www.vadengmpp.com/owners-manual/pontiac/2005-Pontiac-GrandAm.pdf
