05 SV6 ABS Traction system issue
buhhda05
Ohio
I changed my front pads a few weeks ago. Ever since the change, my ABS system light and my Traction control light comes on at least once a day and my ABS kicks in for no reason. When I got the new pads I noticed that the brake pads themselves were a little taller and longer than what I think what were OEM pads. Any suggestions as to what to look for or do for this problem ?I never had any problems before the brake change.......thanks in advance!!
did you disturb the connections to the ABS sensors when you did the brake job? You may have broken a wire inside the insulation or one of the connectors is corroded. You would need the system scanned to know which wheel is causing the issue.
