My 07 montana rear quarter windows not working. fuses are good, disconnected battery that didn't help. anybody have any other idea that might help find the problem?
Well I doubt that both motors went bad at the same time ,how about the switch or a wire came off the switch ? One way to trouble shoot this is put a volt meter on the motors when someone pushes the switch and see if you read any voltage,then this will determine where to start looking also do the same at the switch. Also read this thread it may intrigue you. I am not familiar with the 2007 but do you have a power window lock out switch and maybe it got pushed by accident? Good luck and keep us posted .
