Good day I am new to this forum thing but I'm hoping someone can help I have a 2007 torrent with 240k km on it and am experiencing erratic tach only in the mornings almost like moisture is getting into a sensor or harness. the tach will jump a few times by maybe 200 rpm then drop to zero, then the transmission seems to stay in a gear feels like 4th. if I pull over shut the car off wait about 10 min start it back up it will run fine the rest of the day. spedo works fine. not sure if I should be chasing the speed sensor in the tranny or the crank sensor. car runs perfect after I get through the morning hick ups.
I'm at a loss with this issue. also there are no obd2 codes being thrown
