1960 Brake lights
vinman
I have a 1960 Catalina I lost my brake lights , all other lights work , turn singles , head lights and the rear lights but not brake lights , I took out the brake switch and checked it with a alt. meter and it checked out fine , I also checked the the fuses and there fine , the brake lights were working fine 2 weeks ago , am lost, any help will do……….
Did you test the socket for the bulb?
I assume it uses 1157 bulbs?
no not yet will do that tomerow , might just buy a new switch maybe its fauilty
You tested it with an ohmmeter?
yes a ohmmeter . i put the leads on the terminals and it beeped , i pushed the button in and it stopped beeping , or it beeped when the button was pushed
So you confirmed the switch is good. You have to look and test the bulb sockets and the connection on the switch for power.
Problem solved ,it’s the brake switch adjustment , took the switch out reconnected it and bingo got my brake lights back , thanks for all the help……..
Nothing like a free repair!
But did notice one thing, I got power brakes drums, when she’s in the garage and I push the brakes;by my hands, she’stiff, when I drive, she’s more free, I guess I got to figure out the screw
setting…..
