I need some help or advice. I have an old 64 pontiac Bonneville 389 that I just tuned up. Question I have is what to reference for the timing marks. There is a pointer on the timing case and two hash marks on the flywheel. I know timing should be 6 degrees before top dead center but when I plug dist. vacuum hose which mark is correct for that timing?
Thank you in advance
Jim
Jim
