1966 2+2 conv.
tinmantam
Member
florida
I'm about to put a new radio and rear speaker in my 2+2 and wondered if there was any tricks or hints on replacing the rear speaker?
none that I'm aware of, it's not like a modern computerized car. I would recommend disconnecting the battery when changing the radio.
I put the original AM radio & rear speaker into a '68 Catalina I had. The car had the "Sepraphonic" option, which was a dash mounted front/rear fader control. I took out the rear seat & side panels to chase down the original speaker wire. There's just a hot (+) wire, the speakers ground (-) to the vehicle body through the mounting. Just make sure you have good electrical mounting contact (no plastic washers/shims).
GL
