1966 convertible body bushings
steve b
bought body bushing kit from summit all bushings are the same with exception of the course support with that being said the bushing below front of drivers and passenger door seem to be smaller than the rest summit says its the right kit anyone had this issue i assume i have wrong kit
Did you check if Ames Performance sells a different kit?
checked ames not showing anything
What part number did Summit sell you?
i will thanks again
I used that kit on my 67 chevelle everything went fine except the two bushing locations you mention the supplied bolts are to long , I suspect its because the bushings and bolts should be shorter, that being said I used the taller bushings with shorter bolts I dont see any issues everything linned up good.
