Rems66Pont
I recently had to replace the heads on my 326 engine. My son and I were getting ready to re-assemble everything when I noticed that the lifters were not sitting on the cam shaft lobes correctly. They seem to be sitting half on the cam lobes. There is 1/4" back and forth movement. When I pull the cam forward, the cam lines up where it should be but I can push the cam to the rear and it is half off the lobe. I know the thrust plate keeps it from going too far forward but what would keep it from going back too far? I have had nothing but problems with this engine and would like to find another engine to put in it but they are too pricey.
