I’m having an intermittent problem with my 1966 Lemans. It’s happened about 6 times to me so far. Seems like it happens after I’ve driven a little while. I get in the car and it won’t even turn over. I have battery power to everything, just nothing happens when I try to start. I wiggled the wires behind the ignition switch and it fired off.
It happened this Sunday after a 2-hour drive. Wiggling the wires didn’t resolve the problem. I’m not sure if I have a wiring harness issue or an ignition switch issue now. I made a hot wire jumper and plugged it into the harness and started the car. I then put the harness back on the car hoping it wouldn’t start, but it fired right up! Does anyone have any experience with these things? Are there any known issues that happened after the car gets warm?
