Hello everyone, I just picked up a decent Lemans Conv. I have a few questions that maybe you all can help me with while I wait for the manuals to arrive.
1) How easy is it to replace the convertible top switch? I verified it is indeed the switch but can not get to the connector easily. I am tempted to solder to the existing leads.
2) When the top is down, it does not go all the way. It goes pretty close to getting the cover on but is tight enough to pull the molding up. Is there a trick or something I am missing? Can I drive around without the boot cover?
3) It appears to have horn buttons on the spokes of the steering wheel but they do not work. After checking it appears it may be an aftermarket option as they do not work.
4) There is a bright white light on the dash in the speedo cluster that stays on but no cover over it. Does anyone know what that is for and if I should be worried? Very annoying.
5) Is there any advice or things I should check out to make sure the car is good? This will be my first A-body I will be wrenching on.
I have more but this should last me until my chilton and fisher manual come. I wasn't really looking for this but I think the deal was too good to pass up. What do you all think it is worth with new interior, 2spd, 350 2 barrel? Some minor surface rust underneath but the worst is the front of the rear quarters.
