oldpontiac69
- Sep 12, 2015
Now i am not clueless, but I am having issues with the ignition switch on this vehicle. Originally, the only way the vehicle would stay running is if i held the key forward about 1/2 way into the crank position. If i let it go back on it's own to ignition, it would die. So, I figure the switch is culprit, because no amount of adjustment would solve the problem. Now, I purchased a new swich from Ames, and the vehicle will crank, but not run at all. In the ignition position, there is power only to the 2 brown wires out of the switch plug. I always thought pink was ignition? I am thinking i got a faulty switch, unless i am missing something. The vehicle has been retrofitted with an HEI setup, and I have always been on the assumption that with the key in ignition position, there should be voltage at the BAT+ terminal of the HEI, correct? Any help would be greatly appreciated. I need a switch diagram as well. Pics are included. thank you.
