1970 Lemans cigarette lighter removal
pep23cars
Central IL
How do you remove the cigarette lighter housing from the dash of a 1970 Pontiac Lemans sport?
Two types:
Push in : the tangs pop out and keep the lighter housing in the hole.
Screw in : inner housing unscrews from the front . ( most common)
Doug in P.R.:cool:
the shiny chrome bezel doesnt unscrew friom the front?
You are right Mel, ( cant rememember fixed it above:o ) sometimes they rust up together and you have to cut them apart with a Dremel from behind the dash.
Doug in P.R.:cool:
Thanks for the suggestions. The chrome bezel does not screw off, or at least not easily, as I have tried. I will try unscrewing the housing from the back.
