I just replaced my valve cover gaskets. I had to remove the AC brackets and other little stuff to make room. After I reinstalled them the tach blower and power windows do not work. I checked the wiring around the area I was working. I did have to disconnect a ground wire connected to one of the AC mounting brackets. I checked the ground by attaching another ground wire directly to the negative on the battery. Still nothing is working. Does anyone know what may have caused all three to not function? I looked at the heater fuse looked good but did not test it.
please help. thanks
please help. thanks
